Results 1 to 10 of 13
Thread: Fog Light Switch Question
    Jul 2011
    Chicago Area
    Just bought this switch for a '71 Targa and installed it, everything works fine except the light tube inside has a dab of red paint at the end and does not light up the green lens very well and the red shows through the green lens. Shouldn't this switch have a clear light tube that illuminates just the green lens? Seems like this light tube is for a switch knob with the small button type lens in red.
    Attachment 350508
    Mike Fitton # 2071
    2018 911S Carrera White
    Sep 2012
    Philadelphia, PA
    Quote Originally Posted by mfitton View Post
    Attachment 350508
    Mike, could you take a photo of your light tube for me? I'm not sure I have the correct tube; here's a photo:
    Thanks.
    Serge
    Early S Registry #2457
    Jul 2011
    Chicago Area
    Quote Originally Posted by Veronica87911 View Post
    Thanks.
    You have the correct insert mine is wrong, see below:
    Attachment 350665
    Mike Fitton # 2071
    Jul 2011
    Chicago Area
    Anyone know where you can get the clear insert tube that looks like a golf tee that Serge posted above?
    Mike Fitton # 2071
    Jul 2011
    Chicago Area
    Bump, can the experts here chime in please! Thx!
    Mike Fitton # 2071
    Nov 2002
    San Dimas, CA
    You might try Gary Constantine of Brezelwerks. I don't think he makes such things now but he does related stuff. Maybe you could talk him into it.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Sep 2012
    Philadelphia, PA
    Mike,
    As you can see from the photos, the parts do not fit together. No matter what I've tried, the green light will not go on because the light tube sticks out past the knob. Am I doing this wrong? Help here, folks is much appreciatedName:  IMG_4030.jpg
    Attachment 350665
    Serge
    Dec 2011
    Victorville CA
    I just installed a fog light switch and some TTG lights. There are two different types of light tubes. The golf tee and red the tipped one that is straight like the photo.
    Jul 2011
    Chicago Area
    Mike,
    Serge you may have the earlier fog light switch that takes the stick with the red or green tip, if so your knob and golf tee are wrong, you may need a knob like this:
    Attachment 350898
    Mike Fitton # 2071
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by Bob Harriman View Post
    Stoddards has the pin with colored tip in three colors: red, green, and yellow.
    I thought those were for an early knob that looks like this:
    Which brings up my question. The old lights in my car are both (I don't have a 4-way flasher) a sort of orange and at least one isn't original. Does anybody know if 1965 911s were supposed to have different colors?
    I have a fog light switch and a Webasto heater switch.
    Jim Alton
    Torrance, CA
