Thread: Brake Fluid Resevoir short tubing from resevoir to master cyl line
    PET shows these two short pieces of tubing as part 901.355.927.00 and 901.355.927.01
    I can't find them anywhere but I'm guessing the reason is it is just simple tubing used for some other purpose.
    The two pieces run from the reservoir in the back of the trunk to the two lines that go through the floor of the trunk to the master cyl. They are only a few inches long. Can someone tell me what material I can safely use for this?
    Thank you
    The hose is sold by Porsche in small bulk. Like one meter. You will have a bunch left over. G
    Thank you G. I thought as much. I was hoping for a size and whether or not it is supposed to be clear plastic or of some other material.
