Thread: seat back not working 67 902 stock seats, front
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Haven`t tried to fix this yet...any precautionary insights with disassembly....cliff
    ( Passenger side)
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Yes, wear safety glasses when you disassemble the recliner mechanism-- the spring in there could open your garage door and could turn you into a pirate faster than you can say "Arr!"
    Reassembly is a different matter- you must compress the spring using a slotted shaft that can capture the free end and move it under tension around the retainer. There are some old diagrams of how to construct such a tool in up-fixen.
    Self-described Porsche nut Darryl Deppe fabricated the below: you can see his results on his page here: http://www.darrylsgarage.com/912/912int.htm
    Mar 2006
    8903one
    Thanks, I figured there was a degree of danger with the recliner mechanism.... mine is locked in a slight recline position; glad I don`t sit there! No complaints from any passengers; just not even with the drivers side.....cliff
