Thread: FS: 1973 Carrera RS Tribute/Hotrod – Beautifully Restored
    - Started its life as a 1969 911T
    - It’s been driven about 400 miles since its restoration/build and has a spectacular, high quality Gulf Orange paint job.
    - Engine: 2.7 ltr. twin spark with electronic ignition (Electromotive) and Weber 46 IDA carburetors, 7R Magnesium case. Built to RSR spec (per previous owner) and freshened about 4k miles ago. Estimated at 220 hp. Has headers (no heat), Leistritz muffler, no oil leaks.
    - Freshly rebuilt 915 Transmission, new Sachs Power Clutch, resurfaced flywheel.
    - 930 Brakes on all 4 corners, 930 suspension and 930 steering rack.
    - Zero Rust
    - Steel flares - rear
    - Large front oil cooler
    - H4 headlights (like new)
    - Crack-free dash
    - 15x7 and 15x8 Fuchs (real and freshly restored), new tires
    - New rubber seals (OEM) all around
    - New RS door panels, new Appbiz RS lightweight carpeting, new black headliner
    - New K&N Air Cleaners with Rain Hats
    - New motor mounts, new starter, new battery (single, located in Smuggler’s box), new brake master cylinder, fresh brake fluid, fresh transmission fluid, fresh motor oil and filter, fresh four wheel alignment.
    - Radio delete
    - $97,500. Car is located in NH
    to the top
    Price reduced to $97,500.
