Results 1 to 10 of 16
Thread: Jay Leno's Oil
    Jay Leno's Oil
    I'm sure there have been many threads about oil but doing a search for "oil" seemed like a bad idea - however, if anyone can direct me to some previous threads it would be appreciated --
    I just watched a Jay Leno video with John Wilhoit and they talked about older engines with worn camshafts because they used "modern" oil without zinc
    I have been using Castrol 20W50 for 20 years in my '73 911 that gets about 2000 miles per year on it - are my camshafts worn? I change my oil and filter once a year.
    should I be using Stoddard's oil for old Porsches (or some other special oil for older cars) or stick with my current habit?
    thanks for any feedback
    73 911S Targa
    May 2009
    West LA
    I use Brad Penn 20/50 and my '73 is running fine.
    Registry Member #1583
    Quote Originally Posted by popowitz View Post
    good choice;
    Castrol is not something I would use
    thank you - just ordered a 12 pack of Brad Penn
    73 911S Targa
    +1 on Brad Penn; we sell a lot of it!
    keith
    '75 RS/RSR-look | '73 CB750 | '70 TD250B
    r gruppe # 436
    Senior Member csbush's Avatar
    Jan 2009
    San Antonio Texas
    I really don't want to get in the oil debate, and have no doubt that Brad Penn is "better", but I have used Castrol for 20 years, and my cams are not worn, nor is anything else as I am using standard bearings. I have (for other reasons) been in the engine enough recently to know the status. However, oil has changed over the years and they are taking out the anti-wear additives which Brad Penn apparently has. For that reason, and on the advice of our local shop, I include a quart of Valvoline Racing oil when I do the oil change, and that adds sufficient additives. I use Castrol because it is more widely available, affordable, and it has worked well in my engine.
    Chuck
    Early 911S registry #380
    '70S
    '75S
    '96 C4S
    '65 R69S
    As Chuck says, everyone has a preference in oil. I've used Mobil 1 15-50 for over 35 years with no problems, and i can find it at my local FLAP. I've been tempted to switch to MOTUL, as they use a newer better synthetic than Mobil, but then I think, "why change if I've never had a problem?"
    Before that I used Kendall or Pennzoil when they were still made from Pennsylvania crude, which is no longer the case.
    I think Brad Penn IS the old formula for Kendall.
    Bahia Red '72 911S
    Meerblau PTS 2019 Speedster
    ES #333
    Quote Originally Posted by 69Sman View Post
    yes - this is our understanding, from our Penn rep.
    keith
    r gruppe # 436
