Results 1 to 2 of 2
Thread: FS: 1970 Conda Green 911T Coupe 2.4S Spec
    Junior Member
    Sep 2015
    Colorado
    Conda Green/Black. CofA. Original engine number 6107676 matches chassis number 9110100945. Excellent condition Stuttgart Porsche factory-manufactured chassis, i.e. not Karmann. Underside condition is excellent: Zero rust. No repairs. Original pans. No crack in dash, which has speaker delete. At $66,500, you will not find an early 911 which drives better. Pulls like an S. Handles exceptionally well for early 911.
    Fuchs 6Jx15 wheels, 3-clip centers, 911 361 020 00 with Fuchs emboss, some with original ink stamps. Vitaloni period-correct mirrors on both sides. Racemark period-correct sport steering wheel. Optima battery. Drilled rotors on front. Factory front anti-sway bar is an uncommon and substantial performance option; it was optional on all models, including S. Front fender mounted oil cooler. 5 speed with Weltmeister short shift kit. Original engine was rebuilt to 2.4S specifications at German Motorcraft in 1999 at estimated 20,000 miles ago. Rebuild includes new 84mm Mahle S pistons and cylinders, crankcase oil squirters and oil pump bypass modification, turbo oil pump, GE40 cams, Carrera pressure fed tensioners, Weber carbs, twin air intakes, RSR clutch. Windshield washer works. Clock works. Good Spies Hecker repaint in original 2626-G Conda Green. Original seats are in average condition.
    One owner from 1976 through 2013. Serviced at Tuthill Porsche while in England. Owner had the underside of the car waxed periodically. Mileage is unknown due to speedometer repairs. Odometer indicates 34,000 miles; estimated mileage based upon service records is less than 140,000 miles.
    More photos at https://goo.gl/photos/W2kpBkPCntE6qA1M9
    003 LH Side 2.jpg001 LF Quarter 1.jpg016 4.jpg004 RF Quarter.jpg035b.jpg150.jpg300.jpg
    Maurice Gaubatz
    1971 Light Ivory 911T Targa
    1968 Tangerine 911 Coupe Restoration
    1954 Polo White Corvette
    Junior Member
    Oct 2015
    Lovely car. Sent you a PM.
Tags for this Thread
