Results 1 to 10 of 12
Thread: M5 bolt for fuel sender
    Oct 2010
    Denmark
    What is the correct M5 bolt for the fuel sender for the swb cars 1965-68 ?
    thanks
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Member 1488 MrJTP2001's Avatar
    Nov 2008
    Denver area
    It is shown in the PET as an AM 5x12 bolt with a M5.3 washer.
    Tony
    68 Sporto Project
    2016 Boxster
    Oct 2010
    Denmark
    thanks, do you have a picture?
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    here you go
    Member #2683
    Oct 2010
    Denmark
    Tak skal du have
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Oct 2010
    Southern Ca.
    The washer is an aluminum washer .
    Apr 2012
    Simi Valley Ca
    That is referred to as a "Cheese Head" screw.
    Bob B
    Atlanta, GA
    Quote Originally Posted by Richy View Post
    I have noticed this before. What is the reason they used aluminum? I believe McMaster Carr sells the Cheese Head screw, thou no sure of sizes carried.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Oct 2010
    Southern Ca.
    I believe aluminum was used to help seal possible leaks , same with the oil level sending unit .
    Atlanta, GA
    That makes sense. I just haven't seen anyone mention it as a "crush" washer before. It probably should be replaced if removed I guess?
    Mark Erbesfield
    1957 356A #58648
