Thread: 70S Rear Trailing Arm Question
    When I bought my '70S I noticed it was missing the rear sway bar and now I think I know why. The brackets to mount the sway bar are present on the body but when I look at the rear trailing arms there is no place for the pin bar to locate the drop links. Has my car been fitted with arms from a T? Also, it looks like I can drill into the arm to mount the ball pin - anything I should know before I break out the drill? Finally, cannot seem to locate new pin bars from the usual suspect, anybody know where I can get a pair?
    Port Macquarie, Australia
    This thread should have everything you need... http://www.early911sregistry.org/for...swing+arm+ball
    John Forcier
    EarlyS #1987
    Restoration Saga
    Fishcop - thank you very much!
