Thread: Price check aisle 4
    Price check aisle 4
    I picked up a fresh engine (case type 911/85) built to 2.7 MFI RS specs a couple years ago built by a very respected local builder. P and Cs were Mahle 2.7s, S cams, 3.0 oil pump, 2.4 s dizzie, Gus re-worked 019 MFI pump, Aaron went through the 2.4 S TBs and stacks, steel is all new zinc. ..fuel lines, crossbar, drops etc, shroud and aircleaner are all perfect. I have the correct MFI fuel pump, fuel filter console etc...everything except the heat exchangers. Consider the build list to be completely correct. Beautiful engine.
    I was going to use this for my 914-6 and now I am in the middle of building a different engine for the 6.
    This should be an engine in an RS clone. I know what the induction is worth. And I have a pretty good idea of what it would cost to build this engine. I need some help pricing the complete engine. As much as these types of (need help pricing) ads look like an cheap effort to advertise...this is not. I know what I have in the rebuilt engine and the S induction. And if I cannot recover those costs, I will keep it for another project.
    Reply to the post or shoot me a PM.
    TIA
    Speedo
    registry# 1283
    May 2009
    West LA
    This engine that Marco built and sold is similar to yours. GLWS.
    http://www.early911sregistry.org/for...ighlight=marco
    Registry Member #1583
    2.7 RS spec
    Got some pics finally. T injection pump massaged from 015 to 019. Same with the TBs and stacks. Pistons Mahle 2.7 8.5:1 RS.
    registry# 1283
    I've got the same motor- great motors, perfect for a hot rod.
    Phil
    Early S Junkie # 658
