Thread: Recoiling Seat Belt
    Mar 2010
    Altadena, CA
    Recoiling Seat Belt
    Is there a way to fix a built-in recoiling seat belt mechanism in a 72 coupe? Half the time it has to be coaxed to pull the belt out and the other half of the time it will not re-coil the belt. Is it a matter of lubrication? Any thoughts?
    Steve Hoskins
    1972 Sepia 911 T Coupe
    1970 Conda Green 911T Coupe
    1968 Tangerine 911 T Targa Soft Window
    1960 Silver 356 Coupe
    1956 Polyantha Red Speedster
    2007 Meteor Gray 997 Coupe
    Aug 2009
    SF Bay Area
    Quote Originally Posted by portiapete View Post
    Your belt material is probably worn and starting too curl up. When that happens the belt will not retract properly. Just a sign of age.
    Jim
    The Netherlands
    Open the widest of the two plastic covers and you will find the lock/retract wheel. Pull the webbing and see what is going on. If you are lucky it just needs lubrication...
    Cees
    Did the 72 come with retractable belts ? I have a set of fixed ones on my 72 and they annoy the $%#$% out of me... I wouldn't mind a swap if something's being repro'ed !
    Greg.
    72 911T - 73 2002
    #1461
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Greg D. View Post
    Yes, they were an option. It is easy to fit your car with inertia reel seat belts. Yes, the fixed belts are a pain in the butt.
    Jim
