Results 1 to 9 of 9
Thread: does anyone have photos to share of the front wiring harness?
    Oct 2009
    Indiana
    i've done several 'searches' of this forum's tech info, but can't find what i'm looking for...
    does anyone have photos to share of the front wiring harness for a SWB (preferably '68) wiring harness? I would be especially interested in enough detail to show how the harness is attached to the inner fender and how it is wrapped. (mine is wrapped in electrician's tape, but it looks original.)
    thanks, in advance.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    68 911L sunroof +webasto
    untouched (68000km) but super rotten
    also has the electrician tape wrapping
    Feb 2011
    Surrey, UK
    From an untouched (now restored!) late 66 MY (May66) swb
    Again shows the tape wrap, and I hope you can see the routing/attachment points.
    Mick
Size:  147.4 KBName:  P5110252.jpg
    Oct 2009
    Indiana
    bump for additional photos from others.
    the tape wrapping, rather than shrink wrap, is interesting.
    Quote Originally Posted by mshaver51 View Post
    thanks, in advance.
    It's really not electricians tape, it's 'harness' tape which isn't sticky. When you get to the end you make one wrap with sticky tape to hold the end.
    Oct 2009
    Indiana
    Ed,
    thanks so much! that is helpful.
    Oct 2010
    South Carolina
    Do a search for GM nonadhesive harness wrapping tape. Substantially similar to what Porsche used.
    I have access to two 1968 cars and both have the plastic tube covering and not tape. Both cars are Karman built. i also have access to a 1967 911 Porsche built car. It has the wrapping tape on the harness. Moito's 911L is also Porsche built and uses the tape.
    Mshaver, is your car Porsche or Karman built?
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Oct 2009
    Indiana
    WOW! i believe that mine was Porsche built, but you make an interesting question.
    i will go back to the auto store and see about the wrapping tape.
    this is GREAT!! thank you all.
