Results 1 to 10 of 15
Thread: Determining build month of 71 T
    Jul 2014
    Long Island NY
    Trying to determine build month of my 71 T, the silver VIN decal on the DS door jamb was trashed and the COA doesn't list it. I know its a late 71. Someone had mentioned that I can pull the clock and (assuming it is the original, which it is) and that will have a stamp on it that is a pretty good indication. Is there any "formula" out there to determine this from the VIN itself.? Any help appreciated. Thx
    Apr 2004
    35,000 ft
    Best bet is to post the vin and let others with similar vins tell you their build dates.
    May 2005
    Oroville, CA
    The "formula" is: your car probably wasn't made before the last remaining original date ....
    Most electrical and many mechanical parts have a date.
    I agree with posting your VIN. It will get you closer than you think.
    H
    Jul 2014
    Long Island NY
    Thanks Harvey and Sonett. The VIN on 71 is 9111112612, any help on a build date, much appreciated.
    My 71 is Vin 9111100966 and mfg date per COA is 12/70..... Also noted that my instruments are same dates as are the rims. Seems yours was later production than mine.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Jul 2014
    Long Island NY
    Thanks Frank, have all 5 orig wheels and will check dates again on those and maybe pull the clock.
    Junior Member
    Mar 2014
    The Netherlands
    VIN on my car is 9111120924 and left the factory on October 6th 1970. Instruments are original and from 09/70 as is a lot of the other dated components.
    Registry #3026
    '71 911 T
    www.klassieke911912.nl
    Looks like your car was built in March/April of 1971. Its a targa right?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Jul 2014
    Long Island NY
    yes, it is a Targa. Thanks for all the input here. With the info given here, should be able to nail it down
    Aug 2006
    Chicago area
    I own a 71T with a build date of 3/71. VIN 9111121839. I would suspect that it could be Mar, but is probably an Apr build.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
