Results 1 to 10 of 12
Thread: Need Help Identifying Fan Housing
    Junior Member
    Jan 2011
    Ft. Worth, Tx
    Can anyone help me with this early fan housing. It apears to have missing digits in the casting number but there are no obvious signs of them being ground off. Is this a correct number? Thanks for any help.
    If the fan is 245mm diameter, it is 67 sand cast Mag, that appeared when die cast Mag fan housing weren't quite ready. G.Led
    My 66 is missing the 0 in 901, I thought because of the Peugeot thing but who knows?
    66S, yours is a 250mm sand cast ALU fan housing.
    Thats good to know. Here is another one I have, aluminum. The machining on the middle rib stops on the sides leaving it rough cast on top unlike the one on my 66 which is machined all around.. I have some swb mag housimgs somewhere but I suspect the one in question here is aluminum by the H trademark. Didnt Mahle cast the mag parts?
    Fan dimension will tell tex if it is Mag or ALU.
    Junior Member
    Jan 2011
    Ft. Worth, Tx
    It is definately Aluminum.
    Jan 2011
    Sunny Southern France
    Circled H is for "HONSEL" and they cast magnesium parts. Lots of, ans still in business!
    Olivier.
    Senior Member pss's Avatar
    May 2014
    Netherlands
    i have seen several 1964 fans and early 1965 fans where they did not yet master the numbers to stick in the sandcasting. what is the diameter?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    Tex, you say it's ALU, but please confirm diameter of fan?
