Results 1 to 7 of 7
Thread: standard or longer studs for 7 and 8x15 wheels
    Aug 2010
    Colorado
    I'm putting the rear suspension together for a 69E with RS rear flairs. The car will have 7 and 8x15's and 205, 225 tires. I'm not sure if I'll need a longer stud length and spacers for the proper fitment or can I say with standard length studs. Any input would be helpful.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    I use 7 and 8 by 16's with normal studs. I am pretty sure you will be ok on stud length with any Fuchs unless you start putting spacers in (which you need for certain combinations).
    Aug 2009
    SF Bay Area
    Chris
    The standard length stud in the 69 will be just fine. Those studs are longer than the ones that came standard in your 67.
    Jim
    The Netherlands
    RS's have a 7 mm spacer at the rear wheels.
    Cees
    Aug 2010
    Colorado
    Thanks for the quick input!
    Chris
    www.reSeeWorks.com
    May 2005
    Oroville, CA
    Quote Originally Posted by RSexS View Post
    Cees
    Only for the 7X15s when they are used in the rear...
    The 8s don't need them. Or in many cases, won't tolerate them.
    H
    The Netherlands
    7 mm spacers
    Good point Harvey, I never took them of and the 8's with 225/50/15 tires do fit nicely.
    Kind regards,
    Cees
