Results 1 to 10 of 11
Thread: What is this socket for?
    Lightbulb What is this socket for?
    Hello,
    I found this brown socket under the dash of '72 911S. What is this for? This is not an ash tray light as the light works.
    Thank you for your help in advance.
    Takahiro
    Not sure about the socket but the wire looks like its for a speaker. For a rear speaker?
    I do not have a rear speaker.
    Thank you.
    That might be the point - pre-wired and available.
    Bill
    1969 911T - sold
    2001 911 Turbo - sold
    1996 911 C4S - returned
    1982 911SC - gone
    1960 356 Roadster - sold
    follow the wires and see where they go!
    Apr 2003
    Portland, OR
    What Ed said ^^.
    I think it is not factory as it has two brown wires which typically are grounds on our 911's. It almost looks like a length of lamp cord for a PO kludge.
    Harry
    Member #789
    2009 MB C300
    and, remember... if you find one PO kludge, you'd better check the entire car before it burns up...
    looks like a speaker connection from a Becker radio
    Hello,
    Thank you for your comments. I will follow the wire under the dash.
    Oct 2010
    South Carolina
    Carmel - the Becker DIN connectors have one spade and one pin.
