11/25/15 Edit: I've decided to build these with rechromed original trim rings. $1,800 + shipping. They're available to reserve right now with a 50% deposit and will be ready for delivery in 3-4 weeks.
OK, this isn't your normal for sale post - it presents an interesting originality vs. restored dilemma (at least to me - light geeks are easily entertained.)
I recently acquired a core set of H1's for the purpose of restoring them. However, after I disassembled and cleaned them I discovered that they were much, much better than cores. They're originals in fantastic condition with only one small flaw, which is the interesting part. First a few pictures...
These are all of the parts. The BOSCH housings, BOSCH reflectors, trim rings and mounting screws are all original and in great condition. I'm adding new correct BOSCH H1 lenses and lens gaskets.
This picture illustrates the excellent condition that the reflectors are in - no need for replating with these.
The backs of the reflectors look amost NOS, including the BOSCH sticker.
The original BOSCH housings are in perfect condition and the original headlight adjustment labels are still there, something I rarely see.
The original mounting screws, which can be identified by the tapered tips, are still with the assemblies and are in perfect condition.
All of the adjustment screw heads are perfect with no gouging. They look like they have been used very little. Even the copper ground straps are bright and untarnished.
These units could pass for NOS if not for one little thing. Here's the rub (literally)... The chrome trim rings are original and in beautiful condition - but they have a little patina. They don't have any scratches or dents but when viewed from certain angles they look like they may have been burnished a bit when a buffer was used on the car (one also has some over-spray on the inside of the rim which is no big deal). I like the way they look personally and would prefer to use them as they are but they would probably not be considered perfect on a concours car. I can have them rechromed but that involves removing the adjustment screws which requires changing the way the screws are mounted when reassembled. Not really a big deal as they're secured inside of the trim rings and the differences don't show, they're won't be as original as they are now.
I love originality and it's pretty special to find a set of H1's at this level of original condition - I would love to reassemble everything as is. I will sell them for $1,600.00 in original configuration. If you would like to buy them with rechromed trim rings the price is $1,800.00.
Comments welcome.
Cheers,
