Results 1 to 2 of 2
Thread: Hella 128 + TTG running together
    Oct 2010
    Denmark
    Is it possible to run with Hella 128 under the bumper fogs together with TTG fogs together on same wire and foglight switch ? im unsure if 4 x 12 v bulb is pulling to much current through the wire
    thanks
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by lars1965 View Post
    thanks
    Lars
    Wow! You must have some serious fog where you live.
    More to the point, four 55 watt bulbs will pull 18⅓ amps at 12 volts (15.7 amps when your alternator takes the voltage to more like 14 volts). I checked a few sources that rate a 14 AWG wire (similar to the metric size in a 911) somewhere between 15 and 20 amps, so you'd be in an area of concern.
    Your 50 year old switches are a bigger concern. They're harder to replace and that kind of current isn't good for the contacts.
    I would urge you to add some relays and run hefty power wires from the battery to the relays.
    Personally, I would run driving lights with the Hella 128s rather than four foglights but its your car.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
