Thread: Date marks on early Cookie Cutters
    Junior Member
    Mar 2015
    Northern Ireland. UK
    Hey all,
    Allen here from Ireland. I am restoring a US 911T from 1973. The car has dated Fuchs on it ('71) but these are not mentioned on the COA and I'm pretty sure the basic wheel on the '73T was the Cookie Cutter - it's first year?
    So, I'm looking for a set of '73 Cookies. I have bought a set of Cookies for my '78 SC and there is a very clear date mark on the back of these - in this case a '77' in a circle. But I may also buy a set from a guy here in Ireland and the one's he's selling don't appear to have a date mark on them. He thinks they may be off a '74 car. From the photos he's sent it looks like these have identification marks in different places than my '77 wheel, although the part numbers are there and are the same of both sets.
    So, does anyone on here know if the date was somewhere else on earlier Cookies? Or maybe it was stamped on in ink like some early Fuchs?
    Here's a photo of the date mark on my '77 wheels, looks to be part of the casting process rather than stamped.
    All help much appreciated.
    Al.
    May 2005
    Oroville, CA
    73 ATS (cookie cutters) will be 3 prong cap style wheel.
    H
    Senior Member Darren65's Avatar
    Aug 2011
    UK
    I purchased a set of Cookie Cutters for my 2.4E to make up a winter wheel/tire set......couldn't believe my luck when 2 of the 4 turned up dated 12/72, same build month as my car .....
    I'll take a photo of the date code as soon as I get a chance.
    Cheers,
    Aug 2011
    UK
    Had a photo in my file, you can just see the date stamp on the bottom spoke, let me know if you need a close up.
    HTH
    Junior Member
    Mar 2015
    Many thanks Harvey,
    I think that means that the wheel itself will have an obvious lip inside the centre for the cap prongs to catch onto? Like my early Fuchs? Can you confirm that?
    I know the wheels I am looking at don't have their original centre caps.
    Are you also saying that the '73 Cookies won't have a date stamp/casting?
    Thanks again,
    Allen
    Junior Member
    Mar 2015
    Hi Darren,
    I'm that slow at posting that I didn't see your very helpful replies before I sent my last one.
    So it looks like a '73 Cookie would have the same type of date stamp as my '77s, as well as having the lip for the three pronged centre caps.
    The one's I'm looking at are definitely ATS so the mark must either be there somewhere or worn off which is unlikely. At £200 maybe I should just buy them and see what I end up with!
    Thanks all,
    Allen
