Results 1 to 10 of 10
Thread: FS: SWB 911 Rear Shoulder Belt Mounting Bolts
    SWB_ShoulderBoltSet_04_800x600.jpg 68RearShoulderBeltBolts,Polished_04_800x600.jpg
    PET -67 911 Fig 8/12-00, #16 644.803.121.00 Retaining pin (Collar) Qty: 2
    Material: Aluminum, 6061
    Finish: Anodized, Type II, Clear
    Weight: 23.21 grams
    The fasteners are all stainless steel:
    PET -67 SWB 911 Fig 8/12-00, #17 900.142.002.01 Lock ring, M08 DIN 7980 Qty: 2
    PET -67 SWB 911 Fig 8/12-00, #18 900.142.004.01 Spring ring, M12 DIN 7980 bost. Qty: 2
    PET -67 SWB 911 Fig 8/12-00, #19 900.119.007.02 Pan-head screw, M08x45 DIN 6912 Qty: 2
    The price is $40.28 per set.
    USPS flat rate shipping in the US is $5.25
    PET 68 911 Fig 8/12, #11 901.803.123.20 Shouldered bolt Qty: 2.
    It was instituted as a running change for the following chassis numbers:
    30 8091-on 911 Coupé, 911 S Coupé
    35 5463-on 912 Coupé, Porsche
    46 2711-on 912 Coupé, Karmann
    50 0465-on 911 Targa, 911 S Targa
    55 0326-on 912 Targa
    Material: Titanium, Gr 5 (6AL-4V)
    Thread: 7/16–20 UNF 2A
    Finish: Choice of machined, glass bead blasted or hand polished surfaces.
    Weight: 34.37 grams
    The price is $49.46 per set.
    Oct 2009
    Indiana
    Can I get two (2) sets of the '67 ones, please?
    pm en route
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    @jim
    how far is the development of the correct snap hooks based on the Tekla, to fit the early one´s?
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    JimmyT's stuff is always the best.
    Junior Member
    Dec 2018
    Hello, Are these still available?
    Both styles are still available. If you're still interested, please send me a DM.
    Quote Originally Posted by JimmyT View Post
    Hi Jimmy,
    Are you able to make the Retaining pin (Collar) in steel instead of aluminum? Aim would be so that the snap hook seat belts have a stronger connecting point and theoretically safer in an accident. Per my correspondence with Mike at Partsklassik they don't recommend the snap hook seat belts attached to aluminum knobs.
    https://www.partsklassik.com/p-1546-...eft-65-68.aspx
    Thanks!
    P.S. I am also unable to send a DM (waiting to post more than 5 times).
    Actually I just tested and the Partsklassik snap hook belts won't fit on the aluminum collar.
    Both of the parts shown in the first post are used with the Teka seat belts that were carried over from the 356. Here are changes in the shoulder belt ends during the early years.
    In '68 the mounting bolt threads changed from M8 to 7/16" but the old seat belts remained the same. A new design of 3-point seal belts from Repa was also used on some cars. Instead of snap hooks they used simple tongues with holes through which hex head bolts passed into the body. They were covered by a plastic sleeve for a more finished look. American aftermarket seat belts also used the same style steel tongues, but they were wider and could not accept the plastic sleeves which left the mounting bolts exposed.
    I think that it would probably be easiest for you to forego authenticity and use the eye bolts that Mike sells.
    PCaricous Fanaticous G50911's Avatar
    Jul 2014
    SF Bay Area
    i’ll take a set of the 67 SWB ones. DM me your payment method. thanks.
    1967 911 - #308439
    1971 911 - 3.6 hotrod aka Vader
    1989 911 - Carrera Cabriolet
