Thread: Fuel pump
    Fuel pump
    I found this at the bottom of a box miscellaneous Porsche parts.
    Does anyone have an idea what it goes to ?
    Thank you in advance,
    Woody
    Name:  Dec 1 007.jpg
    Name:  Dec 1 006.jpg
    Name:  Dec 1 005.jpg
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    the MFI pump on the 70E looks the same
    sits below smuggler box on a sepatate bracket
    http://ww2.early911sregistry.org/for...l-Pump-bracket
    edit:
    from the marks on the pump it looks more like it was mounte on this bracket --this sits on the rear torsion bar tube
    http://ww.early911sregistry.org/foru...e-Pump-Bracket
    Moito,
    Thank you for the help.
    Now, I will hunt to locate the appropriate bracket.
    Woody
    Banned
    Nov 2004
    Scottsdale, AZ
    Woody,
    Could also be for a 2.2T (carbs). Bosch # on the end of the pump will tell you.
