Results 1 to 2 of 2
Thread: Help with MFI linkage disassembly/throttle body removal
    Jun 2015
    San Diego, CA
    I want to remove my throttle bodies to check for condition and wear and do flow testing, but I can't figure out how to remove the linkage main cross bar from my 1972 911. It rides in a needle bearing that's pressed into the right side plastic stack assembly, and it appears that I cannot remove the plastic stacks without first removing the cross bar. What am I missing? It's not obvious to me how the cross bar is held in place.
    Am I on the right track here? What is the easiest way to remove the throttle bodies from a 2.4L with the plastic stacks?
    Ben
    2012 997 C2S Platinum Silver
    1972 911T Coupe Tangerine Sold
    2006 Cayman S Speed Yellow Sold
    You have to remove the plastic stacks , then they just pull outward off the shaft.
