Thread: Alternator?
    Feb 2004
    Hermosa Beach, CA
    Alternator?
    It's about time for a new alternator on my 67S.
    The mechanic says that there is a bad diode and I have some other minor electrical problems that could be related.
    There seems to be a fair amount of choices; rebuild, buy new reman, buy new original specs, buy new upgraded specs/amps, buy used, nos, etc.
    Can anyone recommend the best direction to go or point out the pros and cons?
    Thanks!
    Josh
    We are fortunate to have a very good rebuilder in the Fort Worth area, so rebuild original is our choice. I don't know if new Bosch is still available, if so yes, do that, avoid changing types that require modifying your existing wiring or regulator types.
    Try ABCPartswerks in Wisconsin. My 67S before and after
    Feb 2004
    Hermosa Beach, CA
    Thanks guys. Sounds like I should look in to rebuild. Doigthom, looks great.
Tags for this Thread
