Results 1 to 8 of 8
Thread: Balancing MFI Airflow tool question
    Feb 2012
    Mississauga, On
    I'm a total newbie at this but want to properly balance the airflow of my 911S stacks after installing a newly rebuilt MFI pump. Ive never used a syncrometer before so could use some advice on what would be best to use.
    Any advice would be appreciated.
    Rob
    Just get the same synchrometer as used for carbs.
    Feb 2012
    Edmonton
    I see you're in Canada, I have one like this
    http://www.cip1.ca/ProductDetails.as...C%2DC10%2D7125
    Feb 2012
    Mississauga, On
    Thanks to the 2 of you for your input.
    @jrbennett - is that the correct size for the MFI stacks? If so, Ill order today. Thanks
    Or this (plus you get to look like a mad scientist when doing the balancing! )...
    http://www.allzim.com/store/are-mano...zing-tool.html
    Peter Kane
    '72 911S Targa
    Feb 2012
    Mississauga, On
    I might even be able fool my wife into thinking I knew what I was doing with that...or I poke myself in the eye with it and she goes back inside shaking her head
    This one might be easier to use. Its close to what is in the CMA manual.
    Jun 2015
    San Diego, CA
    My STE SK model synchrometer fits the plastic stacks and the throttle body bores of my 72 just fine.
    Ben
    2012 997 C2S Platinum Silver
    1972 911T Coupe Tangerine Sold
    2006 Cayman S Speed Yellow Sold
