Thread: How to fill holes that were drilled in the floorpan??
    How to fill/patch holes that were drilled in the floor pan??
    I just picked up a 911S Targa project. The previous owner drilled three holes in back of each seat in the floor pan to mount shoulder harnesses. What recommendations would you have to patch these holes? They must have been sealed pretty good when done as there is no rust around them.
    Thanks!
    Kevin
    Early 911S Registry Member Number 3210
    1960 356B
    1970 911T
    1985 Mercedes Benz 280TE
    Quick fix:fiberglass and seal
    Proper fix:steel disc, weld and seal
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    I would cut out some round 'fillers' in some 1mm steel and either weld them in or, if you don't want to affect the interior sound deadener and bottom schutz use some JB Weld layered to hold the fillers in place.
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Quote Originally Posted by Cam Arnott View Post
    Thanks very much!
    Kevin
    1960 356B
    1970 911T
    Quote Originally Posted by obliviousmonkey View Post
    Thanks very much.
    Kevin
    1960 356B
    1970 911T
