Results 1 to 10 of 11
Thread: Wiring harness seal
    Senior Member tomlu's Avatar
    Jan 2012
    Sweden
    Wiring harness seal
    Wher to find the correct seal for the wring harness
    May 2006
    CT
    A bicycle inner tube cut and reversed is a very close replica of the original.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Jan 2012
    Sweden
    Perfect
    Did they use hoseclamps on the body and tape
    on harness http://youtu.be/PiRMKcmkh8o
    All of the SWB and LWB cars with unmolested tunnel areas I have worked on had a thin walled rubber sheathing as in your photo...However the sheathing was fitted OVER the metal nipple and secured with a white tie wrap as found in tunnels and on the orange foam defogger hose. McMaster Carr has a virtual exact thin wall rubber tubing/sheathing that I have used. The tie wraps are generic.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    I agree with Mark. Not a separate piece, but rather the outside sheathing pulled over the stub.
    You might want to look into cleaning the stud on the right side of the pic, as this is for the engine ground.
    Peter Stey
    1973 T Coupe with 2.7MFI
    1970 S Targa (sold but not forgotten)
    Jan 2012
    Sweden
    I use an accelerator rod / coupling boot with the end trimmed, A factory part and fits nicely.
    Bernd Buschen
    R Gruppe # 357
    71' 914-6 Original Owner
    70' 914-6 GT Stoddard Built
    69' 911E Scott's car
    70' 914-6 Sold
    IIRC the rubber sheath was about 1 meter long on my 72.
    Secured with 1 ziptie at the bulkhead.
    bob moglia
    '72 E sunroof coupe
