Results 1 to 1 of 1
Thread: FS: Turbo calipers
    Oct 2004
    Cambridge, MA
    FS: Turbo calipers
    Set needing some care in a rebuild. Note that one of the keepers has a small bit broken off in the caliper. Also a small scrape you can see (4th pic down, caliper on left: bright spot).
    EDIT: As Bert pointed out over on Pelican, the rears have been machined so that they will fit on standard narrow-body aluminum trailing arms but they will not work on 78+ Turbo trailing arms.
    $1750 OBO + shipping.
    Tru6 Restoration & Design
    69S Targa, Velvet Green
    73T Coupe, Gemini Blue
    Early S Registry #1462
