Thread: what do these hubs fit?
    Not sure where to place these, they came in a batch of parts.
    All input welcome.
    Thank you and happy new year!
    ~J~
    air cooled only
    J, measure the depth of the hub body.
    32mm is from the non-vented rotor 1964/1965
    40mm also for the non-vented rotor, but a widened front track, check the little white spec book to verify by serial numbers when this applies.
    Note this is a desirable hub to allow vented rotors to fit wider rims under unmolested front fenders....with other companion modifications... shhhh - old racers secret.
    47mm is a 1969> vented rotor hub, it can also can be used on earlier cars needing vented rotor spacing.
    Bob
    Early S Reg #370
    Thank you very much Bob, they are the early 64/65 type non vented. Any interest from the group? I have no need.
    ~J~
    air cooled only
    Banned
    Nov 2004
    Scottsdale, AZ
    They look to be in pretty crappy condition.
    Yes they are horrid
    ~J~
    air cooled only
