I drive my 69 911 at least weekly with no issues. Went out to start it and NOTHING. Battery is fine. Is there some master system failure point in the ignition switch or elsewhere?? By nothing I mean no horn, lights, no nothing.
1969 911S Targa
1970 911S Coupe
1973 911T w 3.2
1972 Alfa GTV 2000
1st- Check all grounds.
Battery to body grounds have been known to corrode.
Early S Registry #235
rgruppe #111
Battery...............start with the easy fixes, as I`ve been told several times
—Juan Manuel Fangio[48]
”What would PORSCHE do”
Ignition switch electrical portion at back of switch. That or the switch itself. I had that failure and replaced the entire mechanism as the lock was getting weak too.
Good idea to start with the battery.
Exact same thing happened to me a few weeks ago. Spade connection off post on starter solenoid. Took me quite a while to find that one.
'66 912 with a 2.2
'62 Lotus Seven S2
'66 Lotus Elan
'63 Karmann Ghia convertible
'76 Alfa Spider
I've had problems with the relay that the start switch wiring loom connects to.......found next to the flasher relay........in my 69 which gave the same symptoms that you describe.
Tony
does 'known good' mean the battery was tested on a large, cart-based carbon-pile battery tester at an electrical shop?
I would use a test light and few jumper wires and trace it down. As sithot said, check the grounds first and check out the positive side from there.
Paul Harrop 12.5% German.
Early S #2059
