Thread: FS: 1970 Porsche 911 S
    Senior Member Orbit's Avatar
    Oct 2010
    Jupiter , Florida
    1970 Porsche 911 S
    VIN 9110300822
    Engine Number: 6301123
    Production Number: 100 1975
    PRICE: $85,000.00
    Matching numbers engine, engine number is 6301123. Missing the original Mechanical fuel injection. Correct Deep 6 x 15 Fuchs alloy wheels. Car does have rust in the floor pans as shown in the pictures. No evidence of any major accidents. There has been some rust repair done on the car many years ago, the battery area has been repaired, the front gas tank support has been replaced and the vertical fender supports have been replaced. A partial area of the floor pan on the drivers side has also been replaced, you can see this in the pictures. Original undercoating on most areas of the car except where repair work has been done. I do not have any books, records or history for the car. Car does need a complete restoration. Steel 911 S front spoiler. Alloy 911 S front calipers. Complete original front oil cooler, lines, and thermostat in place. Car does run and drive. Original color appears to be white. I will tell you everything I know about the car, nobody likes surprises. I have tried to take the most detailed pictures that I can, there are at least 100 pictures on the website. Please go to Orbitracing.com, galleries , current projects.
    There are at least 100 pictures up on the website. I took off the fenders and the bumpers so I could expose everything I can. If there is anything else that you want to see just let me know and I will get a picture up. I do not want to mislead anybody, the car needs a COMPLETE restoration. The car does run and drive. I would plan on rebuilding the engine and gearbox and completely going thru the suspension, brake system, etc.
    Please let me know if you have any questions.
    Rodger@orbitracing.com
    Oct 2010
    Jupiter , Florida
    More Pictures
    There are at least 100 more pictures on the Orbitracing.com website. Go to Galleries, current projects.
    Contact Rodger@orbitracing.com with any questions
    Oct 2010
    Jupiter , Florida
    Rust in Floors
    I tried to take pictures that show the worst areas of the car. If you are interested to buy this car we can offer to repair the rust affected areas and then the restoration is much easier.
    Oct 2010
    Jupiter , Florida
    Car was hit in rear
    Car was hit in rear, the rear bottom latch panel has been replaced. There is still the original undercoating on the rear frame rails and they do not show any damage so it must not have been too bad.
