Thread: 70S Shifter Question
    Quick question - should the shifter for a 70S have a threaded end where the knob attaches?
    Hi, no it's not threaded it uses a serrated crush ring which sits inside the gear knob.
    HTH
    Alan
    Thanks Alan. Since my shifter has a threaded top any idea what model it came from?
    Cheers
    Kevin
    i think it was 67 and back that used threaded knobs. Once a four speed was available you had to use a knob that would install with the necessary pattern oriented correctly.
