Thread: Question on mounting Hella 139's
    I've done a lot of searches and can't seem to find an answer. If using the correct 139 for a LWB car, it has a single post and nut with a square bracket on the back. The mounting bracket that is part of the bumper has two holes drilled towards the bottom of the bracket. To mount the 139, wouldn't there need to be a single center hole in the bumper bracket? If this is the case, I want to drill it before the car heads to paint. Seems strange that the correct hole wasn't in place from the factory? Any info or photos, that can be provided would be appreciated..Thanks Steve
    1969 911 E #824
    Still searching but I did find this related post...
    http://www.early911sregistry.org/for...8-Instructions
    Peter Kane
    '72 911S Targa
    I thought this would be an easy one for the experts to answer....Who knew...
    1969 911 E #824
    Senior Member 55Outlaw's Avatar
    Dec 2010
    Concord, CA
    I also would like to see some pictures of the fog light mounted to the bumper, I am getting ready to mount my fog lights also.
    Michael Rogers
    Founder Nor Cal Vintage VW & Porsche Treffen and the Nor Cal Vintage VW & Porsche Swap Meet
    1971 911T Targa/gold metallic
    1969 912 Burgundy red
    Rgruppe #833
    https://www.facebook.com/Nor-Cal-Vin...9809110032975/
    Jul 2011
    Chicago Area
    I just had mine mounted on my '71 Targa and it has the same 2 side by side holes like in the picture below. My early Porsche guy who worked on these cars when they were new mounted my 139's on the outside holes on both sides, my guess is the other holes were for different size fog lights. So your brackets are fine just as they are.
    Attachment 362555
    Here is a picture of mine mounted on my car using the outside holes on both sides.
    Attachment 362556
    Mike Fitton # 2071
    2018 911S Carrera White
    Gorgeous car! Thanks for the info. Seems strange that the hole is not centrally located, but your location does seem to fit the bill. I'll do a test mount. The wire grommet on the fog light body exits the top or bottom when mounted? Thanks again for your help...Steve
    1969 911 E #824
