Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Help- Rubber Ring for Securing Fuel System Vent Box
    May 2006
    CT
    Can anyone suggest a source or quality replacement for the rubber ring (P/N 901-201-618-22) which secures the fuel vent box under the cowl in a '69-'73?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Feb 2005
    Lake Tapps, WA
    I've wondered this also. If we could get dimensions, I'll bet McMaster Carr has something that will work.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Tom -
    I just asked Porsche about this yesterday - N/A. Die-cut one maybe!
    - Rob
    I use bungee and join the ends with a crimp connector. All available at my local friendly Ace hdw.
    Jul 2006
    Corvallis, OR
    Try amazon under black rubber bands?
    72S, 72T now ST
    May 2006
    CT
    Thanks. Sounds simple enough. Anyone have a photo of the installation/orientation of the "rubber ring"?
    Tom Butler
    1973 RSR Clone
    1970 911E
    one of my daughters elastic hair bands...not that I would know ; )
    1969 911 E #824
    There are two welded hooks on the body, one in front of the box and one behind. Band goes from hook to hook under the box. Rear hook is more accessible from instrument side.
    May 2006
    CT
    I think I've got it. Thanks for all the help.
    Tom Butler
    1973 RSR Clone
    1970 911E
    The originals were square cross section.....you can get square section o rings...or just a regular round...McMaster
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
