Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: How to clean plastic fuel expansion tank...
    Since this part is NLA, I'm seeking advice on a product that will hopefully remove/bleach the once opaque white tank (that mounts inside the LEFT front fender for MFI cars) that is more yellow/tan than I would like. I assume most of the discoloration and staining is from the inside from fuel and or fuel vapors for the past 40 years or so. Any ideas if it will even clean up? Thanks!
    I have cleaned similar parts with household bleach. Proceed with caution and try small areas first.
    Ed may be correct on how to clean it up, but
    if it was mine and wasn't cracked I wouldn't touch it.
    wouldn't touch it but if you must maybe a soft brush and some Simple Green
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Thanks guys...just to clarify, I believe the discoloration/staining is inside, so that is where I am looking to attack the problem (i.e. bleach as Ed suggested). Cleaning the outside has been done. I admit to not being a 'patina' guy...prefer everything to be as crisp looking as possible .
    May 2006
    CT
    Quote Originally Posted by mac73s View Post
    Mac
    I am interested in your results. I will be facing the same issue in my '70E project. Before and after pics would be great.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    I been told that these are in the works to be reproduced (proper white plastic) p/n 911 201 073 00. So new ones should hit the market in a few months through the usual channels, just an FYI
    I have a few original samples as well and all are discolored and or falling apart so I'm in the same boat as you guys on my restoration.
    Dec 2010
    Southold, NY
    If it is dirt, bleach or a cleaning solution might help - if the plastic has yellowed, there is no way to reverse the process.
    Mbr 3268 Fixer's Avatar
    Jun 2015
    Philadelphia area
    Try Spray Nine. It's alcohol based and safe for plastics. It will whiten it as best it can be whitened.
    Matthew J. Mariani BSID, Member 32689
    Haverford Pennsylvania
    Atlanta, GA
    Quote Originally Posted by aturboman View Post
    Anyone know if this has been repopped?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
