Thread: Turn signal, one side works other does not
    I have a 70E that I am trying to put back together.
    Got new turn signal switch, was missing emergency flasher plug and harness, got one. Plugged everything up and the right signals work but nothing works on left side. I bought a new relay, cheap one from Pelican.
    Is it possible the new relay is back? I check and I have power to relay and going to both sides. When I turn switch to the side that is working I have power leaving the switch to relay and the wires going to both sides all blinking I assume that to be normal as well. I have run separate grounds to housing and checked the others.
    Any thoughts.
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Fuse......
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Junior Member
    Jan 2015
    columbia
    If not fuse, then you might have mixed up the turn signal circuit wires - black with green is for right, black with white is for left, black with green and white is for both and sends power from the relay to the turn signal switch (and maybe through the emergency blinker switch - 1969 does this, I don 't know about 1970).
    Lorenzo
    ex-'66 912
    '65 912 project
    '69 912 driver/project
    I echo the fuse comment. If the other lights work in that corner then the ground is not the problem. I don't know about 1970, but my 1973 E has the drivers side front turn signal on a separate fuse from the other 3. Also, corrosion can be a problem in low voltage systems, so replacing your 45 year old fuses even if they are not blown is a good idea.
    Mark
