Hello,
the COA of my 2,2 T shows: Comfort Equipment and US Equipment, what does it mean ??
Thank you, Ben
Hello,
Thank you, Ben
Ben
After some discussion with Porsche's COA people my 2.2T also had comfort group code 470
As follows:
-velour carpet
-gold Porsche and model
-aluminum door sills
-S rubber on bumpers and doors
-chrome rocker part
-S instruments
-rubber pads on bumperettes
-leather cover on steering wheel.
I also found out that several other option codes were noted on my build sheet that had not been provided on my COA.
If you contact them and ask to check the build sheet they can provide items that were hand noted in the actual "build sheet"
Good luck and hope this helps.
Frank
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
60 Lancia Appia Zagato GTE
US equipment cars differed to RoW/other market cars. The US equipment itself differed over the years. Among others (seat belts etc) it included emission controls (vapor canister etc). I think California cars again differed to US equipment cars, at least for a few years.
Otherwise, all is said.
"Comfort Equipment" is Option 470 for 911T's. Its also known as "Appereance group", that word used mainly around 1970 in Porsche documents. Some say also "S-package", but that was never an official description in P literature.
Registry member No.773
Karin
I had received info from COA folks that option code A01 was leather interior , is this correct.
If not what was the AO1 code. Also what's the code for leather interior.
Frank
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
cant currently help with code A01.
Here are other codes.
Dealer Upholstery folder (dealer only, was in use for clients). 1971 version but content similar to 1970.
1970 Colours USA
1971 Colours USA
1971 Special Colours USA (part of the Dealer Upholstery folder)
1971 pricelist USA &codes (codes for 1970 valid too)
My '71 T Targa came the same way.
Karin
Thanks for your post...great info.
So after review of the interior finishes including seats. There is no code for the finish on seats or inserts.
So how would this info be noted? Would it be a hand note in the build sheet . I have been told that the build sheet would have hand notes. Could the A01 code be used in house to reference a hand note that would identify interior finishes or seat finishes?
How else would someone know if they had leather seats or all leather interior or they had hounds tooth inserts.
Thanks for assistance
Frank
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
