Thread: Couple of engine build questions
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    1.Stymied with an oil line adapter issue on my 72 engine. I need an adapter which goes from what appears to be a 22mm female port in my 7R case to the oil line which uses a 30mm fitting. Any suggestions?
    2. What do you builders use for a torque setting on the mfi injectors?
    As always thank you for any help. Mike
Size:  57.7 KBName:  20160115_114654_resized.jpg
    Aug 2011
    New York
    The adapter is part number 999 136 008 09.
    E Sully
    1973.5 911T
    Be very careful your wrench doesnt slip , ouch!( says the oil tube) ask me how I know.S
    Apr 2014
    New York/Florida
    Quote Originally Posted by ESully View Post
    Thanks, I couldn't locate it in the PET
