Results 1 to 10 of 11
Thread: Paint Code Plate install
    What is the best way to install/re-install the little plate on front of door jamb. It was suggested to snip off the long end of the tiny rivets and glue the 4 heads to the plate and then glue the plate to the car. Any better way to do this?
    I have (or had) rivets to install frame tags on motorcycles. The shank has a twist like a sheet-metal or wood screw.
    Here's a link:
    http://www.thisoldtractor.com/moto_g...45918570-.html
    Early S Registry #235
    rgruppe #111
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    I have used glue to attach the rivets on two different cars and it worked quite nicely and looks good.
    I think it's helpful to leave the rivets intact and just push them through the hole with a dab of superglue or Clear epoxy.
    I have another question for anybody, is how to remove the plate and the rivets . I have a car that's going to go into metal restoration and the plate is in perfect condition and I would like to remove it prior to media blasting the car. Any suggestions? Looks like it would be difficult to drill the rivets out. sorry about hijacking your thread.
    M.A.Spirito
    Just installed one this weekend with these:
    http://www.stoddard.com/90009300102.html
    Worked perfectly.
    Quote Originally Posted by LiveFromNY View Post
    Worked perfectly.
    Yes they will! Picture please (for the curious)
    rgruppe #111
    LiveFromNY, did you use a rivet gun and bucking bar, or are these simply tapped into the sheet metal? Is it even possible to get to the backside?
    Quote Originally Posted by sithot View Post
    Sorry. Wish I could but the car was just put away for the year. Suffice to say that it looks just like any other paint tag.
    Quote Originally Posted by jc4me2 View Post
    Just tapped in with a small punch and a hammer. No idea how you'd get to the backside absent major surgery.
    Atlanta, GA
    In this video posted by another member here, you will see them installing a paint code plate.
    http://www.early911sregistry.org/for...911s-Need-help
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Quote Originally Posted by merbesfield View Post
    At roughly 8:25 for those with little patience.
