Results 1 to 9 of 9
Thread: Real 10K Tachometer
    Dec 2010
    Wilmington, DE
    Real 10K Tachometer
    Real 10K Porsche Tach from ST race car. $3,500. Email markepstein914@gmail.com to purchase.
    Sep 2009
    UK
    Probably RSR judging by the date. What is the part number above the "5. Nice piece.
    Dec 2010
    Wilmington, DE
    Here you go
    Dec 2010
    Wilmington, DE
    Price reduced to $2,995
    So Dave unlikely to be ST dated 10/73 seeing as 2.5ST was on a 72 shell
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    May 2005
    Southern California
    The 911R used the earlier pn '901.xxx', while the 71-72 ST I believe used the later 10K VDO tach with the pn '911.xxx'. This could essentially be a replacement OEM 10K VDO Tach for a 71-72' ST, or a 100% correct tach for the 73' RSR. In a perfect world one would look for a 72' date-code tach for their 72' model year ST, but what are the chances of finding one today? Not being a modified VDO 10K tach unit, but rather a rare OEM 10K VDO tach, I would not hesitate to use it in a 72' ST if I had one. You can always purchase this tach, then used it until you find the correct OEM 72' date-coded unit--but good luck with that!
    Sep 2009
    UK
    I knew the serial collector would chime in. Don't buy it Armando.
    Dec 2010
    Wilmington, DE
    $2,995 + ship
    A part isn't purchased until paid.
    The 9 Store LLC.
    Dec 2010
    Wilmington, DE
    Sold. Thanks. Mark.
    The 9 Store LLC.
