Results 1 to 10 of 13
Thread: CDI 3 pin Box options
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    I've got a 911 E, 1970, with a permatune unit installed. it works very well. But I dont like the look I'd like to have a unit which is closer to the original Bosch 3 pin CDI Box. Would you recomend a refurbished or a an up grade unit from Parts klassisk? Is there any other options?
    Best Nick
    Up grade from Parts Klassic,,,,you may need to get your tach updated however.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    i converted a bosch unit by useing the perma tune internals....
    i think i still have it somewhere....
    Restoration newbie.
    Jun 2007
    San Francisco
    There's also classic retrofit who look to
    have a nice product http://classicretrofit.com/products/...i.html#screen2
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    At $1200 a pop I hope it is a "nice product"!!!!
    Quote Originally Posted by ajwans View Post
    andy
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
    That particular unit has a lot of gizmos in it too.
    Fully programmable ignition advance curve.
    Hard RPM limiter with adjustable ignition cut schemes
    Soft RPM limiter with adjustable ignition retard
    Launch RPM limiter
    Double spark at all RPMs
    Max RPM tell tale
    Shift Light output
    Clutch pedal input
    Tacho calibration
    Upgradeable through firmware updates
    The launch RPM limiter would be good for drag racing. Stutter box, anyone?
    Early S Registry #235
    rgruppe #111
    Jul 2012
    Stockholm
    Thanks for all input! I think I will go for a refurbished CDI box from Parts klassik. Since I don´t have a core one to start with they´ll charge some extra for that, it won´t be cheap but I guess it will be worth it (at least for the look).
    I´ve been in contact with Sarah at Partsklassik and she told me that their up graded CDI box are designed to work with stock Porsche tach.
    Best Nick
    Good choice. They stand behind their products too!
    rgruppe #111
    Jun 2007
    Connecticut
    Any return of experience from people using the PartsKlassik retrofit/upgraded box?
    Did you notice any performance improvement or is it simply more reliable on the long run because of its modern technology (and also offer a built-in RPM limit).
    Put it differently would someone with an OEM CDI box that is working perfectly fine consider to upgrade or not?
    Quote Originally Posted by sithot View Post
    912 1966 - sold
    Quote Originally Posted by damsroy View Post
    I would say leave well enough alone.
