Results 1 to 9 of 9
Thread: Help with Body Plug Info
    Can anyone confirm the existence of and or part number for a rubber body blanking plug for a standard 911 60mm heater hose?
    I recall them being available but have purchased nearly every plug that Porsche has which might be it and no luck so far; other than a nice pile of a couple hundred $$ in body plugs.
    Any leads appreciated; I'm doing a heater delete and want things done correctly.
    MCMaster Carr sells aluminum caps in various diameters....there's one that perfect. slipped right over the flange at the rear body heater valve location.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    That will be my fall back but I'm really interested in an OE rubber / plastic cap.
    Haven't measured, but might be close to the plug in the smugglers box.
    I believe that one is 80mm ?
    Atlanta, GA
    There should be a part number shown in the smugglers box parts manual section. It has a plug and a rubber gasket that goes under the plug. IIRC, I have seen it shown in the part catalog. GLWSearch.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Mark I too have seen them in cars before but for the life of me I've ordered all the plugs Porsche still shows for all the long hoods on this part of the car and can't come up with one.
    If anyone has more info I'd be very grateful, thanks.
    I'm pretty familiar with both SWB and LWB parts books and do not recall ever seeing a 60mm blanking cap, The smugglers rubber cap is 80mm, and non-gas heater SWB cars had a stitched vinyl "boot" blocking the metal horn from the smuggler's box up in front of the instruments. The racers just used what they could find as was the case with the racing department. That's why I went with the nice piece at McMaster. It might as well be factory...especially with black paint!
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Mark I think I'll try what you're suggesting.
    If by any chance you know the part number from McMaster can you Pm me; I'm putting an order together this week.
    Thanks Robert
