Hello
Please tell me how to remove the fastener of the Repa seat belt of photos.
Hello
What does the other end look like? It may be a rivet that will need to have the head ground off to remove.
naba901R I would take it to a professional. Those springs can be nasty and dangerous.
Haasman
Registry #2489
R Gruppe #722
65 911 #302580
70 914-6 #9140431874
73 911s #9113300709
Don't do it Kyotchi... You don't need to remove that to replace the webbing if that's what you are trying to do. If they are not retracting properly, you can always buy these..
http://test.early911sregistry.org/fo...belt-set-72-73
Dave
https://www.facebook.com/Beltwerks-139610016684496/
S Registry # 1660
Le Belgique ST build.
http://www.ddk-online.com/phpBB2/vie...p?f=28&t=42628
Thank you for your reply!
I would like instead of the screw to remove the fastener.
As mentioned, be careful. I made the mistake of removing the screw and spent hours to figure out how to replace the spring while cussing at myself the whole time. To re web you pull it out all the way.
Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
Thin tipped pliers will get them out, you will probably damage the cover a little because the grip is not very strong. The phillips head screws do not seems to be original. Good luck,
Cees
Naba--- Those look like security or anti-tampering screws. The head of the screw is oval-you might show the part to a technician, electrical or mechanical, that works with sensitive equipment. I have seen these screw/bolt heads (oval) used in public washroom door hinges and elect. equipment boxes on city buses and elsewhere.
I works in fully equipped. (^^)
Is it rivet! ?
Thanks!
