My weber ida carbs is leaking a littel between the manifold and the carbs bottom surface, I looks like the gasket is wet /damping . Can this be comepleatly thight with no leaks at all, on a 50 year car
Can new gasket do the trick? or can I also use liquid sealant... together with the gasket or?
how much tourge for the nut?
