Results 1 to 9 of 9
Thread: Sunroof hardware diagram
    Car is a '73T
    The previous owner just fitted the sunroof in place but hasn't finished it
    It's floppy and seem to be missing something
    I have a box of parts that I can't identify
    Can someone direct me to where I can find info on removing and refitting the roof?
    Can the panel be removed without removing the head lining?
    Lightbulb
    This page out of the '73 parts book might help......
    I would assume there are multiple pages in the repair/assembly book that would answer your other questions...
    Thanks, perfect
    Got the wiring sorted. Took everything apart and cleaned everything
    Put it all back together, did nor use any grease
    Haven't fitted the new seals yet
    The roof is operating well except it's stopping few millimetres short. Any idea why?
    Here is what I mean
    Not positive but thought I remembered seeing a description on Pelican Parts re sunroof adjustments.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Try removing the gear driver, and then push the panel forward as far as needed, then reinstall the gear.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Atlanta, GA
    Quote Originally Posted by letsrollbabe View Post
    I have never worked on my sunroof. Does this type of work require the headliner to be out of the car?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    You just unzip the zipper to find the gear box held in place by 2 screws. You may need to release the sunroof panel headliner (which slides in a groove below the panel) part to get it all the way forward. When the gear is out, the panel slides, allowing the cables to move opposite each other where they interact with the small driver gear wheel. Once the panel is in the correct forward position, the gear should repeat that position each time. The last motion of the panel is to lift the rear part up to the roof level, and that is also adjustable.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
