Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Education needed: MFI Air box oil return lines connections
  1. #11
    Anyone know if this plug is still available?
    keith
    '75 RS/RSR-look | '73 CB750 | '70 TD250B
    r gruppe # 436
  2. #12
    Quote Originally Posted by keith View Post
    I couldn't find it, I've used some rubber to seal it ...
    Instagram
    Twitter
  3. #13
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    Two questions on this older topic: does anyone know the part number for the 24mm breather hose, from oil tank to airbox? PET is not clear on that. Second, where is the small (lowest) outlet nipple on the airbox connected with? Thnx for info.
    (Is for '73 MFI)
    Tom
    911S 1973
    Early 911S Registry #176
  4. #14
    Lightbulb
    Tom,
    My '73 parts book lists the hose as:
    901.107.349.04
    The small hose at the very bottom of the air box connects to the breather bolted to the back of the sheet metal... It has a small bung at the top (pictured away from you) The hose collects what condensed oil vaper and it runs downstream to the breather and out the rubber 'drain nipple' (dark black) at the bottom of the breather.... and, if it makes that far, on to the ground...
    Hope this helps,
    cm
    Jan 2003
    The Netherlands
    thanks Chuck!
    Can't find any reference on that number, could you verify?
    In PET online, I could only find breather hoses for the 911T-V and 911T-K models.
    I noticed the smaller tube on a pre-restoration photo of my engine. :-)
    But couldn't find a number for it in PET; Although generic hose, would expect to find a part number for it?
    911S 1973
  6. #16
    Jun 2012
    London, Ontario, Canada
    See here for more detail on the bottom of the airbox breather hose. https://www.early911sregistry.org/fo...highlight=hose
    The small hoses themselves can be found in rubber everywhere, but if you want authentic fabric braided versions, look here for a source. https://www.early911sregistry.org/fo...=1#post1023950
    Ravi
    Early 911S Registry # 2395
  7. #17
    Excellent reference Ravi... Thank you
    Jan 2003
    The Netherlands
    Great info Ravi! thnx.
    have found the numbers:
    24mm hose 650mm long, 90110739400 > now 00004320516
    911S 1973
  9. #19
    Happy to see my old post revived
    Instagram
    Twitter
  10. #20
    Jun 2012
    Quote Originally Posted by swisscheese View Post
    Just be warned the Porsche hose is 10 times the price of the German made Continental brand braided hose in my link. I believe they are identical.
