Thread: FS: Weber IDA setup
    FS: Weber IDA setup
    Fresh rebuild...with minor foot repair. Setup for 2.0-2.7 engine.
    Shafts tight. New gaskets. New floats. Setup as follows...
    30mm chokes
    F26 emulsion tubes
    175 air correction
    170 mains
    55 idles
    Short velocity stacks
    Short air cleaners
    1969 manifolds
    Fresh plated uprights, cross member
    Bellcrank and linkages
    Fuel line fittings and banjo bolts
    Bosch 009 carb fuel pump
    Low pressure fuel regulator
    I can change out jets/chokes as needed...but would rather sell as completed.
    $3200 obo plus shipping
    registry# 1283
    Weber 40 IDAs
    More stuff...
    Please PM me with requests for more pictures or detail.
    Speedo
    registry# 1283
    What was done in rebuild...and price reduction
    Had several questions. So carbs were completely disassembled and the butterflies and throttle shafts removed. Carbs were soda blasted. Bushings were dressed and galleys cleaned. Hardware was evaluated and serviced or replaced. Mechanism is tight and fluid.
    Horns are short as that is what came with the carbs...same with the air cleaners. Manifolds are clean with zero oxidation.
    Price reduced to $3050 obo for original, serviced Italian IDAs with accessories. If you are just interested in the carbs specifically, PM me for an adjusted price.
    Speedo
    registry# 1283
    Price drop to $2900 for package obo plus shipping.
    Speedo
    registry# 1283
    40 IDAs
    Several nibbles, and requests for more pics...but no takers. Price reduced to $2750 plus shipping.
    Pics of the "sides".
    Speedo
    registry# 1283
    Weber 40 IDAs
    Last bump before they go back to the shelf
    Speedo
    registry# 1283
