Results 1 to 10 of 15
Thread: Need 2 small pieces to finish '67S restoration
    Apr 2004
    Denver, CO
    I'm looking for these two pieces that are circled in red:
    1) Rubber buffer piece that is placed in between the trunk floor wiper pump motor mount and the pump itself. I've never seen one but here's where it goes:
    2) The metal clamp (and screw) that holds the fuel tank vent line to the driver's side trunk wall seen here:
    If anyone has these please let me know. Thanks guys!
    Carl Bauer - OBP
    1979 RoW 911SC
    Peter Kane
    '72 911S Targa
    Apr 2004
    Denver, CO
    Thanks Peter. Aase's looks more correct with the 90deg square ends. If anyone has the screw/bolt for the clamp we can wrap that one up.
    PET says that what I thought was a rubber mount under the wiper pump is actually a felt strip. I usually don't believe PET with this type of minutiae... Late 65-67 owners, what do you have under there? Also, if anyone has an original parts book could you post a pic of the page that shows this wiper pump diagram? I'd be interested to see the differences between PET and the original parts book in this case!
    Carl Bauer - OBP
    1979 RoW 911SC
    Peter Kane
    '72 911S Targa
    Apr 2004
    Denver, CO
    Peter,
    Thanks for those links as well.
    FWIW, I've never had good luck with new dealer stock for screws and bolts. I'm hoping we can find one off a parts car or in someone's bucket of bolts.
    Carl Bauer - OBP
    1979 RoW 911SC
    When in doubt...
    www.easypor.com
    Peter Kane
    '72 911S Targa
    Apr 2004
    Denver, CO
    EASY came up empty.
    I'm still looking for everything in the first post. Please let me know if you have any of the pieces I need.
    When in doubt...
    www.easypor.com
    Carl Bauer - OBP
    1979 RoW 911SC
    36 year PCA member
    Dec 2012
    Denver Co.
    I am in Parker Co. and have been restoring Porsches for a very long time and also collecting and parting out 1973 and earlier 911/912 and 914s. I also have a original 67 911 here that is complete for the most part for comparison.
    In the 1st photo it shows a lower bracket for a 68/69 and later windshield washer bottle but has the correct SWB battery area. The other part circled looks like a carbon canister mount which I believe is a latter part also? Steve
    Apr 2004
    Denver, CO
    Steve,
    If you wouldn't mind could you please see what material is between the wiper pump motor and trunk bottom on your '67? Thank you!
    Carl
    Carl Bauer - OBP
    1979 RoW 911SC
    It's a heavy gray felt about 11/64" thick , 1 5/16" wide. Fits under washer, this one from a '67
