Results 1 to 2 of 2
Thread: FS: Rs 2.7 engine case
    Sep 2013
    Portneuf
    perfect 911/83 engine case,boat tailed,shuffle pined, time sert with dilivar ser. 6641042 case only 19,000.us
    also available standard crank with nitrated rods,correct heads ,cams ,throttle bodies,plastic stack
    pump is S but recalibrated everything but pistons cylinders 19,000.us
    Sep 2013
    Portneuf
    911/83 case 1974 boat tailed,shuffle pinned,time sert with dilivar,perfect condition
    ser 6641042 case only 19,000.us
    also available perfect standard crank with nitrated rods,mfi camshaft,correct heads redone with new valve guide
    throttle bodies,plastic stacks ,S pumps recalibrated to RS specs missing only pistons and cylinders
    19,000us
    can assemble for customer
    see photos in post under other Porsche parts (911/83 1974
