Results 1 to 10 of 19
Thread: What Rim is this ?
    What Rim is this ?
Size:  169.2 KBName:  image.jpg
Size:  169.2 KBAs you can see this is Name:  image.jpg
Size:  103.5 KBName:  image.jpg
Size:  87.8 KBdate stamped 1964, chrome finish
    With tight bolt pattern believe this is more like a 911.
    Had this with my 356 Rims.
    So please comment
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    No picture....
    Peter Kane
    '72 911S Targa
    Sorry, photos uploaded
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    May 2005
    Oroville, CA
    What do the other flat spots look like? Probably for a 1964 356C
    HTH
    H
    The bolt pattern is more 911 than 356.
    356 has wide bolt pattern
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Seattle WA
    Quote Originally Posted by 71gold View Post
    356's went to disc brakes (and tight bolt pattern) with the earliest 64 production (made in later 63).
    May 2005
    Oroville, CA
    Quote Originally Posted by Soterik View Post
    +1 As always Eric is spot on.
    Porsche bolt circles
    356 64&64 MY 130mm
    356 63MY and earlier 205mm
    911 130mm
    Sorry, I thought that was common Knowledge.
    I was looking for the subtle differences between the early 911s and 356 disk brake wheels.
    Maybe another thread for that subject.
    H
    Quote Originally Posted by Harvey Weidman View Post
    H
    Harvey do you know the differences?
    There is 3.7 and 3.9 (steel thickness?) but when was that introduced? Do you have any factory info on that?
    Also, may be, black vs dark grey paint or is that LMZ vs KPZ or even aging?
    Richard
    Seattle WA
    356 64&64 MY 130mm
    911 130mm
    H
    I know there's some discussion elsewhere, and Richard alludes to it. I believe I've read elsewhere (maybe Dave Seeland) that there was all steel 904 wheels available (130mm obviously) and I believe they were 3,9 only. I have seen some other threads that seemed to indicate that although the 3,7 was supposedly 356, that there were in fact wheels "mixed" between the 356 and early 911 for 3,7 and 3,9. I can see that happening on spare wheels (either at the factory or at the dealer), but don't necessarily see that happening on the production line. I once owned a very early set of all steel 3,9 wheels. They came to me in a large parts collection from a collector who said those steelies had come off of his 904 (#092). I sold them a LONG time ago.
    e
    I don't know what rim sizes were available for the 904, but 4.5 seems to be small. If so, the earliest 4.5 w/ a 3.9 code we could find would probably a tell re. when the change was introduced.
    Richard
