Results 1 to 8 of 8
Thread: Solex '65 air snorkel help
    Sep 2009
    COPENHAGEN, DENMARK
    I am just on the way to the press :-)
    can some one just confirm the lettering is correct
    got 2 org here, but a guy confused me in the last minut , that they could have different logo´s , numbers
    in different stage of the production "date" early / late ! hope you understand what I am asking for , this is how the 2 I got looks like
    ( not pictured in correct order )
    If some are NOT correct or match yours , please post a picture , this would be much appreciated
    Marek
    That's exactly what I have on mine from a set I have in inventory .... they are painted and hard to photograph, but do match all the markings you have
    Also found an unpainted set, again same markings. This set has the original firing order/valve adjust decal on it, but wait, on closer inspection the "micro top" logo on mine appears to be different....
    John Schiavone
    Connecticut
    May 2011
    Chelsea, Québec
    This is on a prototype 901 engine... Name:  solex.jpg
Size:  64.6 KB the "micro top" looks the same as the one in John's post...
    Member #1616
    Junior Member
    Sep 2011
    Beaverton OR
    Hello - I just posted a question on this decal on another thread - maybe this one will get an answer more quickly. Did all Solex-fitted 911s have this single combination firing order/valve clearance decal on the air filter snorkel? When did P move this information to the indented latch panel with two separate decals?
    Pretty sure all Solex snorkels had the decal. Don't think they appeared on the latch panel untill 66
    That makes sense Ed, so decals on latch panel corresponds to switch to Webers? Correct that Solex equipped cars had no latch panel decals?
    John Schiavone
    Connecticut
    Don't know for a fact that Weber usage was the start of latch panel decals. I'd start looking for period photos or see if parts book gives an indication.
    Sep 2006
    La Quinta
    My '65 (301111)came with no latch panel decals, only the one on the snorkel for the Solex carbs.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
