Thread: 2.2 E engine rebuild question...
    I need to bore out the standard size cylinders on a 2.2 E engine that I am rebuilding...what are the options for repair sized pistons? What is typically done?
    Source for the replacement pistons?
    Thanks much!
    '66 911 - Light Ivory | Early '66 with Solex Carbs
    '72 911T - Aubergine originally | now Bahia Red | "S" options | 2.2S P&C's
    Apr 2012
    SE PA
    Usually you just replace the cylinders and pistons in a set. There were places that would redo or exchange your pistons and cylinders with an oversized bore. 2.2 and 2.4 use 84 mm bore size but the 2.4 has a longer stroke so don't use 2.4 pistons on 2.2 stroke or you can end up with real low compression. JE makes good pistons so you might want to check with them.
    Oct 2010
    Southern Ca.
    Woesner makes 84.5 or 85 .
    Nov 2002
    Fremont, CA
    Used single pistons/cylinders; EBS Racing, parts wanted classified here, Pelican parts wanted
    Good options for replacement of the set:
    1-find a good used set, and clean them up ~$1000
    For likely more life than used parts...
    2-bore cylinders from 84mm to 85mm, use JE pistons ~$1500
    3-bore & replate cylinders w/ Nikasil, use JE pistons ~$2100
    4-use new LNE Cylinders & new JE pistons, ~$4800
    5-Original NOS Mahle Set, ~$5000?
    scott kinder
    kindersport@gmail.com
    Registry #614
    Scott
    "replate cylinders w/ Nikasil". Is that only possible w/ alu cylinders?
    Richard
    Nov 2002
    Fremont, CA
    No, it's possible on Aluminum and Iron cylinders.
    scott kinder
    Registry #614
